spkerer
- Joined
- Jul 6, 1999
- Location
- Leesburg, VA, USA
Could someone clarify exactly what/where the so-called "snow screen" is compared to the so-called "snorkel screen"?
There is an obvious screen where the air first enters the ducting on it's way to the air filter. Visible as soon as you open the hood, very obvious if you're looking for it.
Is there another screen farther back in the ducting between this initial screen and the air filter box? If so, where in this path is it? Do you need to remove the battery and such to access the part of the ducting necessary to get to this other screen.
