Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old May 11th, 2017, 17:47   #1
mittgore
Default 2015 Ford Fusion Titanium
Hey all, so I'm selling back my 2013 jetta tdi next week so ive been looking for a new car, including other VWs, toyota, ford, honda..
I test drove a 2015 Ford Fusion Titanium today. It has 20k miles, 1 previous owner (lease). Everything was great until I took it on the highway. There was a slight shake in the steering wheel and a vibration in the seat when I went past 80MPH. I told the salesman that if they fix that, i would buy the car. My questions are as follows:
- Im thinking it needs an alignment. Is that common for a car with only 20k miles?
- only 20k miles.. should I be concerned with a shake? should be solid. did the previous owner hit a lot of curbs or pot holes?
- if I do show back up tomorrow and the shake is gone, is there any way they can temporarily mask it? I dont want it to come back a month down the road..
VIN : 3FA6P0D91FR140944
mittgore is offline   Reply With Quote
Old May 11th, 2017, 19:11   #2
GoFaster
Moderator at Large
Most likely cause is a wheel out of balance. It may simply have worn itself out of balance - it happens.
It may be due to a worn tire. It may be due to a bent rim from a kerb or pothole.
It's unlikely that any such thing could be masked temporarily - it's either fixed, or it isn't.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old May 11th, 2017, 19:18   #3
mittgore
thanks for the response!
yes! he also did mention doing a wheel balance. I'll look closer at the rims tomorrow and see if there are any dings/dents
Old May 14th, 2017, 06:44   #4
GetMore
Fuel Economy: 56.1/42.7/38.1
It could be on the inboard side, so it might be difficult to see. It is much easier to see when mounted on the balancer.
1997 Passat TDI, RC2, RR .216 injectors, needs a headgasket. For sale.
2010 Jetta Sportwagen, 9W7, Euroswitch, Ed's lights, fog lights, mud flaps, Malone Stage 2 and DSG tunes. Still has full emissions.
GetMore is offline   Reply With Quote
Going to sell my 2000 VW NB GLS - got a 2016 Ford Fusion ScottyP5947 VW MKIV-A4 TDIs (VE and PD) 4 December 6th, 2015 20:09
Passat vs Ford Fusion CT_Gman VW Passat Family (NMS and B7) TDIs (2012+) 48 May 12th, 2014 09:47
Ford Fusion hybrid mileage dieselyeti General Automotive 10 January 3rd, 2014 09:35
2013 Ford Fusion with 1.6 and 2.0 EcoBoost 740GLE General Automotive 20 January 20th, 2012 03:54
Ford Fusion survey tjl General Automotive 3 April 25th, 2005 02:07
Page generated in 0.14625 seconds with 11 queries
[Output: 63.72 Kb. compressed to 57.17 Kb. by saving 6.55 Kb. (10.28%)]
