Old February 20th, 2017, 09:59   #1
gearheadgrrrl
Fuel Economy: Other than the JSW, hard as I try, can't seem tio get below 40 MPH!
Default DSG fluid change- How much fluid?
Doing the "top fill" method, got about 4.2 to 4.3 liters out, weighted 6 pounds, about the same as 4 liters of new fluid. Is the quantity I put in real critical? Debating if I should put in the 4 liters measured by weight, the 4.2-4.3 liters measured by volume, or the 4.5 liters the DIY guides suggest?
GearHeadGrrrl
gearheadgrrrl is offline   Reply With Quote
Old February 20th, 2017, 10:07   #2
jonferns
jonferns's Avatar
TDI(s): '15 Golf
I've always added 4.7 liters via the top-fill method, no issues thus far.
'15 Golf S TDI - 80k, DSG
'12 JSW TDI - 99k, 6MT Buyback complete!
'06 Jetta TDI - 160k, DSG, Package 2, Malone Stage 1, RCD510 Retrofit
'06 Jetta TDI - 230k, DSG
jonferns is offline   Reply With Quote
Old February 20th, 2017, 10:13   #3
narongc73
That's what i did.
narongc73 is offline   Reply With Quote
Old February 20th, 2017, 12:20   #4
gearheadgrrrl
Thanks! The scale I used wasn't that accurate, so I'll split the differnce between the 4.2-4.3 I measured and the 4.7 recommended here and put in 4.5. That's what the DIY article at myturbodiesel.com recommends, and either way it's within the +- .2-.3 they recommend.
GearHeadGrrrl
Old February 20th, 2017, 12:34   #5
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
I thought you were supposed to just add fluid until it overflows from that little tube that goes into the drain hole, at a certain temperature.
Since that sounds extremely easy, why not just do that, and then the level will be exactly where it's supposed to be?
Mike_04GolfTDI is offline   Reply With Quote
Old February 20th, 2017, 13:54   #6
gearheadgrrrl
That's the factory "bottom side" method. Nothing wrong with it, but "top side" "measure and refill" method works better for me as I don't have a lift to raise the car and keep it level. Put it back together and took a test drive, ran the windows up and down and turned the steering lock to lock and the warning lights went out. Drove a couple miles and shifts better, If it doesn't show any leaks I'll put the belly pan back on tomorrow.
GearHeadGrrrl
Old February 21st, 2017, 22:43   #7
Macradiators.com
Macradiators.com's Avatar
TDI(s): 2.0 CR 360hp
4.7 works fine for me, perfect i would say.
CP3 Upgrade
Macradiators.com is offline   Reply With Quote
Change that DSG fluid! Daugen Fuels & Lubricants 28 April 1st, 2014 12:27
DSG fluid change jeff.zienk Fuels & Lubricants 11 May 31st, 2012 11:55
DSG Fluid Change? LeroyFord TDI 101 1 August 13th, 2007 19:11
DSG Fluid Change,Did it Myself dodgevid VW MKV-A5 Golf/Jettas 7 May 30th, 2007 19:48
Dsg Fluid Change engineerorange VW MKV-A5 Golf/Jettas 9 January 23rd, 2006 19:52
Page generated in 0.14267 seconds with 11 queries
[Output: 79.53 Kb. compressed to 68.89 Kb. by saving 10.64 Kb. (13.38%)]
