Old May 21st, 2014, 02:04   #1
Killabee228
Fuel Economy: 52mpg so far
Default Rotella T6 and CJAA motor with DPF delete?
So there is the thread of Rotella and our Turbos. But the majority of what I see are the older tdi's. Would it be a bad idea to run T6 in a common rail engine?
The only reason to run 507.00 motor oil is to prevent ash buildup in the DPF. But since I am deleted; is there a reason to still use 507?
(This has probably been mentioned before)
deAutokey Led foglights - Euro Switch - Malone Stage 3 - DieselDubs Downpipe with Res - CR170 Turbo - Aluminum Bumper Cover - 17" Anthracite Goals - Driver Gear Springs - Euro Cup Holder - Anthracite Plasti Dipped Front Emblem - Neuspeed Turbo Discharge Pipe - DarkSide Developments HP EGR Delete - MICRO-CAN VCDS owner
Killabee228 is offline   Reply With Quote
Old May 21st, 2014, 02:55   #2
homer8869
TDI(s): 2009 JSW
I believe this is the thread you are looking for.
http://forums.tdiclub.com/showthread.php?t=398280
homer8869 is offline   Reply With Quote
Old May 21st, 2014, 07:26   #3
Killabee228
Yes it was. Also a very funny video included.
Rotella T6 motor oil? chgofirefighter VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 18 January 30th, 2016 11:06
Fullerenes in rotella T6? James & Son Fuels & Lubricants 5 August 11th, 2013 08:09
Rotella T 5w40 now Rotella T6??? Joester Fuels & Lubricants 13 February 5th, 2010 16:20
Rotella T6 & Rotella T SB? kwalsh24 Fuels & Lubricants 8 January 28th, 2010 16:38
Rotella T6 werewolf TDI 101 6 January 20th, 2010 15:42
Page generated in 0.14801 seconds with 11 queries
[Output: 57.68 Kb. compressed to 52.40 Kb. by saving 5.27 Kb. (9.14%)]
