Old April 14th, 2014, 12:27   #1
HaNd_SoLo
TDI(s): None...yet
Default mTDI swap into 87 Toyota...planning stage
Hi! I've been lurking around here, on and off, for the last couple of years contemplating doing this swap. The other options were running the stock 22R on propane or a 3RZ from a Tacoma. I have finally settled on an AHU TDI.
Unless I score a deal on another pump, I will more than likely end up using a Land Rover 300TDI pump. I'm not looking for huge power, mostly fuel efficiency, simplicity, reliability and torque. This will definitely be mTDI with a wastegated turbo, please don't sidetrack this thread with eTDI or VNT chatter.
After reading through every mTDI and toyota swap I could find, as well as various normal swaps, there are still a few things I have not been able to find answers to.
What size fuel lines should I be running? The stock toyota lines IIRC are 5/16 supply and 1/4 return. What size are the stock VW lines? With the LR pump being 11mm, I imagine they will need to be a little larger that the VW lines.
I plan on running an inline lift pump. What volume should it be able to flow to keep up with the pump at 5000rpm? I don't plan on running 5000rpm, but if the power bug ends up biting me, I would rather not have to deal with fueling issues.
Which stock (not necessarily TDI) exhaust manifold places the turbo highest up and farthest toward the front (timing cover end) of the engine? I can fabricate an adapter for the turbo, if necessary.
There's more, but that's all I can remember at the moment.
Last edited by HaNd_SoLo; April 14th, 2014 at 13:56. Reason: Forgot to mention which TDI...
HaNd_SoLo is offline   Reply With Quote
Old April 14th, 2014, 15:43   #2
vanbcguy
vanbcguy's Avatar
The fuel lines will be fine the way they are currently.
The vast majority of the fuel drawn in by the VE pumps us ejected out the return again - fuel circulation through the pump is what cools the pump. So an 11mm pump doesn't really need anything different fuel line wise, the actual low pressure feed pump is identical.
Choose a lift pump that can flow 30 gph and you will be fine. Keep the pressure below 10 PSI or you may damage the front seal of your injection pump. Ideally choose a pump like the Facet Posi Flow ones that don't shut off the flow of fuel should the electric pump fail.
Sent from my HTC One XL using Tapatalk
My build thread: http://www.vwdiesel.net/forum/index.php?topic=32967.0
vanbcguy is offline   Reply With Quote
Old April 14th, 2014, 18:17   #3
jimbote
jimbote's Avatar
you can use a trapezoid td manifold or an AFN/BHW manifold although the trap td mani definitely holds the turbo up higher
Old April 14th, 2014, 21:15   #4
HaNd_SoLo
TDI(s): None...yet
Duh... I knew the size determines injected fuel, it just didn't click that it wouldn't affect circulation...
A couple of threads on here led me to believe it was significantly more than that. IIRC, they were down to 1psi or less at around 3500rpm with a 30-something gph pump.
Is this the manifold you're talking about?
Old April 15th, 2014, 00:46   #5
jimbote
jimbote's Avatar
yes ^^^ that is the correct manifold
Old April 15th, 2014, 13:24   #6
vanbcguy
vanbcguy's Avatar
The mechanical pumps have a tiny little 1mm orifice that all fuel must exit on the return side. I don't believe the electronic pumps have the same orifice. It is related to the timing advance on the mechanical pumps - they use the pressure internally in the pump casing to control advance. Anyhow you would be hard pressed to get 40+ GPH through a sub-1mm hole, so really that is as large as your lift pump needs to be with a mechanical pump.
Old April 15th, 2014, 18:40   #7
HaNd_SoLo
TDI(s): None...yet
Very good info, thank you!
Old April 16th, 2014, 09:28   #8
djtc
TDI(s): mk4 golf tdi
I have a k14 wastegated turbo with a top mount manifold for sale!
djtc is offline   Reply With Quote
Old April 18th, 2014, 12:05   #9
HaNd_SoLo
TDI(s): None...yet
Surely, a PM would have been more appropriate? However...
From my reading, the k14 has a bit higher boost threshold and a little better efficiency at 15+psi than stock (k03 or gt15), correct? I'm currently planning on running the stock turbo and the better efficiency would be welcome. I do not want to sacrifice any bottom end boost, though.
This is the exhaust manifold discussed above? The k14 came as two different turbo flanges, the trapezoidal and a triangular pattern, I believe.
Old April 27th, 2014, 09:09   #10
HaNd_SoLo
TDI(s): None...yet
I've got an idea I would like to test out. Does anyone nearby-ish have a junk ALH block they want to get rid of cheap? As long as the transmission and injection pump sides of the engine are undamaged, it'll work. I'm in Sonora.
Old April 27th, 2014, 17:51   #11
vanbcguy
vanbcguy's Avatar
The K14 is a pretty good option honestly. It doesn't have the efficiency or pressure ratio capability of a newer turbo but it will definitely do better than the stock AHU turbo. Won't spool QUITE as early but will still kick in plenty soon.
Old December 7th, 2015, 19:11   #12
rotaecho
But what's the P/N for it? Damn hard to find!
rotaecho is offline   Reply With Quote
1990 Toyota pickup from AAZ to AHU MTDI djtc TDI Conversions 83 February 17th, 2015 16:48
Planning stage MKIV .:R32 swap. Advice needed rspring TDI Power Enhancements 15 February 25th, 2013 06:04
"87 mpg" Toyota ES3 concept car unveiled BHarrison TDI News/Tech 22 May 3rd, 2003 05:08
my '87 4 litre Toyota turbo diesel land cruiser passed emissions! Oil_Burner TDI (Diesel) Emissions 2 February 22nd, 2003 00:15
My '87 DIESEL Toyota LandCruiser passed emissions! Oil_Burner West Coast Canada/USA 11 January 31st, 2003 15:22
Page generated in 0.15536 seconds with 11 queries
[Output: 111.96 Kb. compressed to 94.49 Kb. by saving 17.47 Kb. (15.60%)]
