dodgevid
Took me about 4 hours today to change my DSG Transmission fluid including the trip to Sears to pick up a 14mm hex for the main drain,Got all of my supplies from ESC Tuning and a Vag-Com from Rosstech ok my question has anyone else did this oil change,I had to remove my battery and housing including part of the air intake just to be able to access the filter that is right below the battery,Does anyone know of a easier way to get at the DSG filter housing,the fluid change was easy, but removing all of the stuff in the way took a couple hours By the way going by the temp on Vag Com that bentley manual says my Car held 5.1liters of Transmission Fluid which looks very much like hydraulic fluid
