Old April 17th, 2007, 14:34   #1
drkblujetta
drkblujetta's Avatar
Default Anyone have a TDI ALH Suzuki Sidekick?
Just wondering if this swap has been done by anyone in this club?
I am very tempted as my truck is done out with Toyota axles-dual Transfer cases-37" tires -rock crawlin machine
I am still running the factory 80 HP 1.6L8v motor
Another Drkblujetta (ALH) ..
drkblujetta is offline   Reply With Quote
Old April 18th, 2007, 05:08   #2
Spulen81
Search for deepmud on here, he has a TDI in his Samurai. His is super built up also.
Here is another great link for Suzuki conversions. http://bbs.zuwharrie.com/content?P=8...01f&board=48.0
-1986 Jetta Coupe, AHU, R520s,Alligator 3 bar, D24 manifold, GT2052 - SOLD
-1986 4Runner TDI - SOLD
-1991 GTI-TDI - SOLD
-2011 Golf TDI - GONE
Spulen81 is offline   Reply With Quote
Old April 18th, 2007, 10:10   #3
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
no, but I've a Grand Vitara with a Peugeot HDI :-)
DPM is offline   Reply With Quote
Old April 19th, 2007, 18:27   #4
drkblujetta
Yeah I WISH we could have more diesel options in N.America........
I did see the Samurai........it's a little different than the Sidekick however.
Old April 20th, 2007, 00:28   #5
DPM
Your Sidekick was our Vitara, and was available from the factory with the old Mazda RF turbodiesel. IIRC, that engine was available in NA for a while, so with the right mountings and bellhousing it might be a handy swap?
Old April 20th, 2007, 08:16   #6
drkblujetta
The question is.......
Is it worth importing a motor from Europe.......or just using the ALH....
Old April 20th, 2007, 08:57   #7
DPM
As I said, that engine was used in the US. I'd need to spend a couple of hours trawling the Suzuki parts cd to confirm what all is needed, but a front clip would have it all.
edit.
Wouldn't an ALH be the wrong starting point, if you need longitudinal mounting?
Old April 20th, 2007, 09:08   #8
drkblujetta
I have a few friends that have done the 1.6Turbo swap............
It's too gutless for my liking(unless you put some $$ into it)
I was thinking the AAZ would be more suitable or an ALH
(I have seen how much power they can both produce and they are both impressive)
i know ACME ADAPTERS has the Suzuki tranny to VW engine kit for the AAZ.......
The ALH is different right?
Old April 20th, 2007, 09:15   #9
DPM
Later block has no mounting points IIRC.
Old April 20th, 2007, 09:21   #10
DIESEL DAZZLER
Default Aaz
AAZ bolt pattern for trans is the same as ALH.A custom mount can be fitted on the frt of motor.
09 Jetta TDI 3 pedal 6spd
06 Jetta TDI 3 pedal 5spd
03 Jetta TDI 3 pedal 5spd ,smf ,vr6pp,205's Egt boost gage
81 CADDY AHU,FMIC,11mil ,R 520's,RC2/3/4,Hybrid turbo [ 22v/sprinter inards] Peliquin Diff,air ride.
Kabota Diesel mower
DIESEL DAZZLER is offline   Reply With Quote
Old April 20th, 2007, 09:33   #11
drkblujetta
Just found this on the acme site........
I inquired about the 1.9TD a few years back.......not sure if everything in the kit would work for the ALH
4-CYLINDER Gas/Diesel Kit: S i d e k i c k or G e o T r a c k e r
Kit 6: $835.00 Kit 6 includes the following items:
  • A572 3/8" Heavy duty Adapter plate
  • Flywheel machined ready to bolt on
  • Engine bolting hardware kit
  • Alternator mount for stock Suzuki alt. & brackets
  • Throttle Cable
  • Engine mounting brackets (includes clutch bracket mount)
  • Oil filter housing (1.6 motors)
  • Acme Oil Pan
  • Installation instructions with detailed color photos
  • Unlimited Acme Technical Support
For additional items you may need, please see individual parts available for purchase below.
Old July 2nd, 2007, 20:04   #12
mannytranny
mannytranny's Avatar
TDI(s): 02 Jetta
I too was wondering about this......
How would you do an ALH? Wouldnt it be easier to use a mechanical injectioned car? Less computer stuff to deal with?
mannytranny is offline   Reply With Quote
Page generated in 0.15184 seconds with 10 queries
[Output: 102.88 Kb. compressed to 85.54 Kb. by saving 17.34 Kb. (16.86%)]
