Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Ontario
Ontario Local discussions for those in the Ontario, Canada area.
Old February 18th, 2020, 16:40   #1
3hone
Default LF: DPF delete pipes CJAA
Looking to delete the DPF on my 2013 Sportwagen. Any one have a used set of pipes available?
3hone is online now   Reply With Quote
Old February 19th, 2020, 07:35   #2
ErackTDI
hey
here is a good option i have seen
https://mecevo.com/parts/flowdirekt_...npipe_kit.html
https://youtu.be/YfzhN96wL1o
or another option
https://www.dieseldnatuning.ca/produ...npipe-shipped/
diesel dna is a canadian supplier for darkside i believe
mecevo is candain$$
diesel dna is in usd$
hope this helps if you end up having to go with the new route
ErackTDI is offline   Reply With Quote
Old March 8th, 2020, 15:25   #3
Yai
Thanks for this! How do you think the quality of the downpipe if the Macevo compares to the Buzzken, one? That Macevo looks pretty nice!
Ron,
Yai is offline   Reply With Quote
Old March 8th, 2020, 15:28   #4
Ktmracer358
Just installed a buzzken today on my cjaa. So far I have no complaints
Sent from my REVVL 2 PLUS using Tapatalk
Ktmracer358 is online now   Reply With Quote
Old March 8th, 2020, 19:05   #5
Yai
Yeah that seems to be the response. Buzzken is also my JR auto tuner, so I'll likely just stick with his. Just curious how these ones stack up, as rawtech is the nicer piece, but just too much $$ for a downpipe vs the Buzzken...
Ron
Old March 12th, 2020, 15:06   #6
ErackTDI
personally i like the pipe from mecevo better then buzzken
because of one reason
buzzken uses stainless steel which is great but then the welds are mig welded with mild steel filler ( the welds won't last like the pipes will)
where as the pipe from mecevo is all big welded with stainless filler
https://youtu.be/tNrMND7CdZE opening the pipe from mecevo
https://youtu.be/MCD_2TptZVI sound clips with factory muffler
https://youtu.be/YfzhN96wL1o roughly a year of having the mecevo pipe installed
Old March 14th, 2020, 06:22   #7
Yai
thanks for the review!
Old March 15th, 2020, 02:23   #8
ErackTDI
no problem hope the info is helpful to others
Old March 15th, 2020, 07:36   #9
Uberhare
Uberhare's Avatar
TDI(s): Too many.
Fuel Economy: Depends on what I'm towing!
Any chance the buzzken stuff has improved?
2004 Passat W8 Variant, awaiting BHW swap
Retired: 2005 Passat BHW Variant w/01E 6 gang
Uberhare is offline   Reply With Quote
Can I drive with dpf delete tune with dpf still installed? hubjon VW MKVI-A6 Jetta Sedan (~ 2011+) 11 April 5th, 2018 11:22
CR DPF delete, mid pipe, & Darkside EGR delete. GTSLOW Private TDI Items for Sale/Wanted 10 May 29th, 2017 14:23
Rotella T6 and CJAA motor with DPF delete? Killabee228 Fuels & Lubricants 2 May 21st, 2014 07:26
DPF Delete vs DPF replace Costs ESFlash TDI Power Enhancements 14 March 23rd, 2014 18:56
Page generated in 0.13041 seconds with 12 queries
[Output: 88.00 Kb. compressed to 75.18 Kb. by saving 12.82 Kb. (14.57%)]
