Group, I have tried to search the forums and could not find anything specific to what i am experiencing( or I am not searching properly). Here is the story. I disconnected the battery to replace a airbag sensor on my wifes car. After replacing it I reconnected the battery and I had a whole bunch of lights and errors come over my MFD. The normal ones (steering wheel, etc.) but some different ones as well. I had the flashing glow plug light. engine light and the engine fault workshop. I plugged in my VAGCOM and found the following:
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H11--- Serial number: VWZ7Z0E1677570
Coding: 0050071
Shop #: WSC 03155 444 178572
VCID: 6393AFD59756E1632E9-8036
1 Fault Found:
000550 - Throttle Pedal Position Sensors (G79)/(G185)
P0226 - 000 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 380111 km
Time Indication: 0
Date: 2000.00.00
Time: 00:11:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00101100
Mass Air / Rev.: 0.0 mg/str
Absolute Pres.: 928.2 mbar
Readiness: 0 0 0 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0021122
Shop #: WSC 00066 000 00000
VCID: 3A2D32B1405CC0AB5DF-806E
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
012 - Electrical Fault in Circuit - Intermittent
I don't know about the wheel sensor since that just came on but the issue is with the throttle pedal. I can start the car up and clear the codes while running and they will not come back on while it is running (everything runs/drives fine) but once I shut it off and restart the flashing glow plug, engine and the engine workshop come back. I tested the throttle pedal on another 2006 VW jetta and it works fine. Anyone have any ideas? Hopefully it is a simple fix.
Coding: 0050071
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 380111 km
Time Indication: 0
Date: 2000.00.00
Time: 00:11:00
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.62 V
Bin. Bits: 00101100
Coding: 0021122
1 Fault Found:
