Go Back   TDIClub Forums > VW TDI Discussion Areas > OBD Scanners
OBD Scanners Discussions on using On Board Diagnostic (OBD) scanners/ Diagnostic Equipment related to TDIs
Old March 13th, 2018, 08:40   #1
TDI(s): Jetta
Unhappy 2004 jetta 5speed tiptronic transmission overheating
Good Day ladies and gentleman I have a 2004 VW JETTA TDI 5 SPEED TIPTRONIC TRANSMISSION , I Replaced the Selonoids and I still have a little issues when it changes gears it makes a little noise and you can feel it . I am woundering if I can do live data with scan tool to verify temp . of trans. and at what rpm the selonoids are working at. can some one help??????
lemnorat is offline   Reply With Quote
Old March 13th, 2018, 08:44   #2
oilhammer's Avatar
Fuel Economy: fantastic
Back up.... what kind of noise, and what led you to the conclusion you needed to replace the solenoids?
The ATF temp value can be monitored with a scan tool, yes, but I very much doubt this has anything to do with whatever your problem is. The temp sensor goes bad somewhat commonly, and it can cause poor shift quality, but it always sets a DTC, and I would never describe it as being a noise.
2004 PD Jetta tiptronic transmission question hackler22s VW MKIV-A4 TDIs (VE and PD) 18 December 6th, 2014 16:05
WTB 2004 Jetta TDI Automatic 5 Speed Tiptronic Transmission GPC Paul Neese Private TDI Items for Sale/Wanted 2 October 22nd, 2014 23:33
Transmission Fluid Change 2004 TDI Tiptronic path001 VW MKIV-A4 TDIs (VE and PD) 5 March 25th, 2006 19:05
Changing Transmission Fluid 2004 Jetta Tiptronic path001 VW MKV-A5 Golf/Jettas 5 March 18th, 2006 05:56
tiptronic transmission for jetta tdi 2004 max_gag Private TDI Items for Sale/Wanted 0 December 13th, 2005 17:05
Page generated in 0.12602 seconds with 13 queries
[Output: 52.32 Kb. compressed to 48.27 Kb. by saving 4.05 Kb. (7.74%)]
