here is the video of another occurrence
https://youtu.be/DSIo9mtd4KU
after the engine restarted i actually got the CEL, here is thel og below. All codes later cleared. I actually could not find the ground under the tandem pump, instead there is a ground to the block on the front of the engine below the oil filter accessed from under the car. All cleaned again, seems to be working ok for now, not sure for how long though. Since theres a code related to the ECM could there be some bad connection there? Does the ECM control the starter? Why did the ECM code come up under the auto tran group?
Tuesday,28,April,2020,17:22:54:06633
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.0.1 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: 9BWGR61J954013642 License Plate: 04028-20
Mileage: 194140km-120633mi Repair Order:
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
VIN: 9BWGR61J954013642 Mileage: 194140km-120633miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 038 997 016 L HW: 028 101 181 2
Component: R4 1,9L EDC G000AG 3791
Revision: 12345678 Serial number: VWZ7Z0D0430234
Coding: 0150034
Shop #: WSC 09446 444 84293
VCID: 2757EAC795F4FDBE63-50C8
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 BL
Component: AG5 Getriebe 09A 0262
VCID: 76E9F78352DED43628-50C8
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000 785 00200
VCID: 336F0E97512C811ECF-50C8
Part No: 1C0 909 605 F
Component: 08 AIRBAG VW61 0202 0003
Coding: 12344
Shop #: WSC 00000
VCID: 2757EAC7C5F4FDBE63-508E
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 907 F
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 15234
Shop #: WSC 55113
VCID: 2C5D15EBDC12DEE68E-508E
9BWGR61J954013642 VWZ7Z0D0430234
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00000
VCID: 70E5C19B30BAFA06F2-508E
Address 46: Central Conv. Labels: 1C0-959-799.lbl
Part No: 1C0 959 799 C
Component: 8C Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 04926
VCID: 37773A8715546D3EF3-4A82
Subsystem 1 - Part No: 1C1959801A
Component: 8C Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802A
Component: 8C Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811A
Component: 8C Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812A
Component: 8C Tõrsteuer.HR KLO 0202
10 Faults Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
54-10 - Incorrectly Equipped - Intermittent
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01331 - Door Control Module; Driver Side (J386)
37-00 - Faulty
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
00934 - Electric Window Motor; Rear Left (V26)
01333 - Door Control Module; Rear Left (J388)
37-00 - Faulty
01334 - Door Control Module; Rear Right (J389)
37-00 - Faulty
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio ZSW 0016
Coding: 00031
Shop #: WSC 00000
VCID: 244DFDCBB4C216A646-50AC
End-------------------------(Elapsed Time: 05:03)--------------------------
