mandrake slink
I'm replacing a missing bolt on the turbo oil supply line. Its the bracket/clip that secures it to a larger bolt on the rear driver's-side of the exhaust manifold. Sort of behind the vacuum pump, or directly below the air intake pipe just past the MAF. I think the bracket with the captive nut is bent or installed wrong. Looking for the Bentley manual page # that has a drawing of the oil supply line with it's brackets/clips or a good drawing or picture of the bracket/clip stated above. Need to see what its supposed to look like or what the correct orientation is and I can't seem to find it anywhere. Thanks for any help!
