Old November 26th, 2013, 10:48   #91
BuzzKen
BuzzKen's Avatar
Nice! Good info. At least you're using a good filter too!
BuzzKen is offline   Reply With Quote
Old November 26th, 2013, 11:30   #92
Vince Waldon
Vince Waldon's Avatar
A cautionary CAI tale, with a sad ending:
http://forums.tdiclub.com/showthread.php?t=400983
Vince Waldon Edmonton AB Canada
Canadian Grizzly's excellent low-power/limp mode troubleshooting guide
VW's TSB for scientifically tracking down parasitic current drains
Vince Waldon is online now   Reply With Quote
Old November 27th, 2013, 17:54   #93
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: 130 MPGe
Originally Posted by Rawtek View Post
Hi folks,
I thought I would chime in here since I have some CAI retaled news that I'm sure will spark some discussion.
We just came off a dyno session while testing our new Passat exhaust & tune where we found a pretty significant power improvement with our cold air intake on both the Passat and Jetta. We did 3 pulls with the stock airbox installed, 3 pulls with no airbox installed (just MAF and tube extension) and finally 3 pulls with our CAI. After all the hype about intakes being worthless on our 2.0lcr TDIs we were pleasantly surprised by the results...13whp over the stock intake and about 8whp over just the intake tube extension. These were with a AEM DryFlow filter and yes, the original VW filter was fresh and clean.
Feel free to discuss and/or call me a liar while I dig up the dyno sheets.
So you're saying that your CAI is providing 8 hp MORE than an open intake?
Old November 27th, 2013, 19:28   #94
Digital Corpus
Digital Corpus's Avatar
Hi folks,
Does your filter meet the filtration of the stock filter?
Turbo Upgrade | Engine Rebuild | Photos | Lighting Mods
Dyno Graphs | 4-Bar sensor | GTB1756VK | Hot-swappable 2.5" down pipe | R520's | PD130 intake manifold
Digital Corpus is offline   Reply With Quote
Old November 30th, 2013, 10:36   #95
JFettig
JFettig's Avatar
Last night, I spent a few hours on the dyno, I'm running what some here would call a "CAI", AEM dryflow filter on a 3" turbo inlet. I gained 2hp by removing the filter, it has over 20,000 miles on it
JFettig is offline   Reply With Quote
Old November 30th, 2013, 10:41   #96
Good Ol' Boy
VeeDubTDI's Avatar
Have you happened to compare it to a stock setup? I imagine that the stock setup would be a bit restrictive with your mods.
Old November 30th, 2013, 11:00   #97
JFettig
JFettig's Avatar
no room for the stock setup in my Passat, there is a turbo in the way
Old November 30th, 2013, 12:53   #98
Good Ol' Boy
VeeDubTDI's Avatar
Sounds like a good problem.
Old December 2nd, 2013, 21:11   #99
kooyajerms
grocery getter
kooyajerms's Avatar
I've run the stock setup on my b4 with all my current mods and dyno's it has done. Except for some swiss cheese that is. Doubt that matters.
kooyajerms is offline   Reply With Quote
Old December 3rd, 2013, 14:30   #100
TDI_
TDI_'s Avatar
Fuel Economy: Cool Stuff
The only thing I noticed with Swiss Cheese was the RPMs climbing over 3000+ much easier. It breaths better for sure!
Very First TDI_ 1998 Jetta (300)7,000 Miles On The Clock and Going Up Fast!!!
TDI_ is offline   Reply With Quote
Old December 5th, 2013, 12:10   #101
TDIFan1989
Fuel Economy: 58.68 MPG US (best results)
The way that most VW TDIs are made, they already have a "Cold Air Intake". I couldn't provide photos but if you look at the front bumper on most models, that plastic grill low to the ground is the port that feeds the intake air supply to my knowledge. Having said all that though, I did upgrade to the K&N drop in replacement for my TDI (33-2128) as they are washable/reusable and I will never have to hunt down an exotic air filter or pay for some no name filter. Seems like a win for me.
TDIFan1989 is offline   Reply With Quote
Old December 5th, 2013, 12:13   #102
Good Ol' Boy
VeeDubTDI's Avatar
Thumbs up
Originally Posted by TDIFan1989 View Post
The way that most VW TDIs are made, they already have a "Cold Air Intake". I couldn't provide photos but if you look at the front bumper on most models, that plastic grill low to the ground is the port that feeds the intake air supply to my knowledge. Having said all that though, I did downgrade to the K&N drop in replacement for my TDI (33-2128) as they are washable/reusable and I will never have to hunt down an exotic air filter or pay for some no name filter. Seems like a win for me.
Fixed it for you.
Old April 4th, 2014, 20:31   #103
bhutchins
bhutchins's Avatar
Fuel Economy: best 47
some personal observations. I was running the AFE pro Dry drop in, in the factory box, and decided to try the carbonio intake. The carbonio is louder inside the cabin. then on a trip up to seattle, I was cruising 75 mph getting 42 mpg, when it started to rain.. the milage dropped to 36! the carbonio sucks the dirt and rain directly into the filter, the factory is designed to collect the moisture and large dirt before it gets to the filter. the carbonio filter was completely filthy after 5000 miles
I'm back to factory intake with AFE filter
Sold : 234 WHP / 404 WTQ (550 N-M)
bhutchins is offline   Reply With Quote
Old April 6th, 2014, 13:49   #104
SirSipsAbit
SirSipsAbit's Avatar
Default Did you track N75?
Hi folks,
Hello Rawtek. I have recently installed your full open exhaust and purchased the CAI. When you made these dyno pulls, did you track the N75 at that time? Was there any boost creep or spikes that would potentially be unsafe for a daily driver?
Thank you
Jon
SirSipsAbit is offline   Reply With Quote
Old May 19th, 2014, 14:58   #105
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
http://forums.tdiclub.com/showpost.p...5&postcount=37
Priceless....
oilhammer
www.cardocautomotive.com
Page generated in 0.16782 seconds with 10 queries
[Output: 134.64 Kb. compressed to 112.71 Kb. by saving 21.93 Kb. (16.29%)]
