Mark@MaloneTuning
Vendor , w/Business number
- Joined
- Sep 24, 2003
- TDI
- '14 GSW TDI, '11 Golf TDI, '97 Golf Variant Syncro 1.9L TDI, '96 Golf 1.9L ASV TDI, '93 Eurovan Westfalia 1.9L TDI, '09 BMW 335d, '17 BMW 328d
By moderator: This thread split from original.
Thanks for the compliment guys
ihatehybrids: 17 PSI with the stock ECU is roughly 2 PSI higher than where it should be. 20 PSI with a tune is also 2 PSI higher than where it should be (the tune requests 17.5 to 18.0 PSI). Either your boost gauge reads a bit high, or your straight exhaust pipe may be causing a little boost creep, which is very common with BEW engines.
I sent you a PM about taking a quick boost log to check requested vs. actual values.
Regarding Stage 2 with 40+hp. It's fine for many BRM engines, but most BEWs (2004-2006 MK4 Golf, Jetta, and NB) start boost creeping at that power level, regardless of modification used (ECU tune, tuning box, etc.). A 20-25hp mod is safer for most BEWs, preferably with stock exhaust. Some stock BEWs can handle +35hp or more with absolutely no boost creeping above 18.0 PSI in all driving conditions (e.g. WOT to redline in 3rd gear or higher) but it's rare.
Cheers,
Mark
Cheers,
Mark
