Paulsta
Hi, i removed my IP and took it apart to replace all the seals and o-rings, I think i put it back together properly but now once back on the vehicule the engine turns over for at least 10 secondes then it fires for a breaf momment ( half a second ) then it dies.
I don't have any fault codes
I have 12v on the shutoff solenoid
Question 1
How much fuel is returned to the tank from the IP, i disconected the return line from filter and sent to bottle, after cranking 10 sec. i didn't have much fuel in there ( should i see a flow comming out or just a drible )
Question 2
I put a clear line from a container of fuel siting on the engine and when cranking the pump pulled fuel up the container and into IP, does this mean my IP is pulling enough fuel to feed the high preasure portion of the pump.
Thanks for any guidance on what to do next.
Paul
Question 1
Question 2
Paul
