TomKitt
After a few weeks of trouble free driving, my '04 PD went into limp mode this morning -- no MIL, but there were 3 codes:
Tuesday,09,October,2007,11:13:38:23653
VAG-COM Version: Release 704.1
Address 01: Engine
Control Module Part Number: 038 906 016 H
Component and/or Version: R4 1,9L EDC G000SG 5675
Software Coding: 0150031
Work Shop Code: WSC 00066
3 Faults Found:
16792 - EGR Potentiometer (G212): Signal too High
P0408 - 000 - -
Freeze Frame:
RPM: 2058 /min
Torque: 92.0 Nm
Speed: 14.0 km/h
Temperature: 82.8°C
Voltage: 14.21 V
Lambda: 2.5 %
Duty Cycle: 10.0 %
16787 - EGR Valve (N18): Malfunction
P0403 - 000 - -
Freeze Frame:
RPM: 2646 /min
Torque: 74.0 Nm
Speed: 42.0 km/h
Temperature: 84.6°C
Voltage: 14.21 V
Lambda: 47.1 %
Lambda: -1.3 %
18628 - Oxygen (Lambda) Sensor B1 S1: Signal too High (Rich)
P2196 - 000 - -
Freeze Frame:
RPM: 1092 /min
Torque: 88.0 Nm
Speed: 6.0 km/h
Load: 43.9 %
Voltage: 14.29 V
Bin. Bits: 00001100
Torque: 144.0 Nm
Temperature: 84.6°C
Readiness: 0 0 0 0 0
They're not listed on the Vag-com/Ross tech wiki. Any help would be appreciated.
Address 01: Engine
3 Faults Found:
P0408 - 000 - -
Freeze Frame:
RPM: 2058 /min
Torque: 92.0 Nm
Speed: 14.0 km/h
Temperature: 82.8°C
Voltage: 14.21 V
Lambda: 2.5 %
Duty Cycle: 10.0 %
P0403 - 000 - -
Freeze Frame:
RPM: 2646 /min
Torque: 74.0 Nm
Speed: 42.0 km/h
Temperature: 84.6°C
Voltage: 14.21 V
Lambda: 47.1 %
Lambda: -1.3 %
P2196 - 000 - -
Freeze Frame:
RPM: 1092 /min
Torque: 88.0 Nm
Speed: 6.0 km/h
Load: 43.9 %
Voltage: 14.29 V
Bin. Bits: 00001100
Torque: 144.0 Nm
Temperature: 84.6°C
