OR we do our OWN oil changesDesertV10 said:And you have successfully demonstrated this to the dealers? There is another thread about a dealer claiming to void warranty by using owner supplied 506 01 oil instead of 505 01. I'm not defending that dealer but the situation happened. Until the dealers get with the program it seems we are stuck.
Do yourself a big favor and research 505.01 vs. 506.01 attributes. You won't take long to come to the conclusion that the latter is the only oil for your very expensive tdi. The other thread you referenced was for the 1.9L tdi, not your exotic engine. I've not heard of the dealers insisting on Touraeg owners using 505.01. If this is the case, I urge you to contact VAG and have them set VWoA (and the N. American dealership network) straight on the requirements for your engine. This is serious stuff!!DesertV10 said:And you have successfully demonstrated this to the dealers? There is another thread about a dealer claiming to void warranty by using owner supplied 506 01 oil instead of 505 01. I'm not defending that dealer but the situation happened. Until the dealers get with the program it seems we are stuck.
tditom said:Do yourself a big favor and research 505.01 vs. 506.01 attributes. You won't take long to come to the conclusion that the latter is the only oil for your very expensive tdi. The other thread you referenced was for the 1.9L tdi, not your exotic engine. I've not heard of the dealers insisting on Touraeg owners using 505.01. If this is the case, I urge you to contact VAG and have them set VWoA (and the N. American dealership network) straight on the requirements for your engine. This is serious stuff!!
BEWARE! I would watch them carefully and make sure they don't put any additives in your engine along with the oil. They have been know to throw a bottle of their oil additives and charge you extra. I would also clearly state that they are not to overfill your engine when they add the oil. They do a high number of oil changes every week and could care less if the quality of your oil change is good or bad.tditom said:Desert-
Have you ever had an oil change done at the dealer? What oil did they use?
what we need is some "juicy" literature that actually shows they made a boo-boo regarding the current 505.01 "VS." 506.01....especially for the V101 TDI with the DPF.wny_pat said:505.01 was created in 1998.
506.01 was created in 2001.
506.01 is required for the V10 TDI regardless of what the owners manual says. They made a mistake in printing it, just like they did in the PD manual when it first came out here in the U.S. The biggest problem is that VWofA seems to be on their own page when it comes to oil. They don't care what their parent company says. This issue has the possible makings of a great lawsuit someday.
I agreeleicaman said:I would suggest you contact VWOA and or VAG to really get something in writing of some kind on this one.
506.01 it IS then . . .SUNRG said:[the following is strictly my opinion] - the V10 will be 100% fine using 505.01 at 10k OCIs. you will enjoy increased performance if 506.01 is used. i think 506.01 is exclusively prescribed for the V10 to mitigate its fuel thirstyness. cheers!
But Rob, these certainly don't read like its only an option:SUNRG said:[the following is strictly my opinion] - the V10 will be 100% fine using 505.01 at 10k OCIs. you will enjoy increased performance if 506.01 is used. i think 506.01 is exclusively prescribed for the V10 to mitigate its fuel thirstyness. cheers!
http://pics.tdiclub.com/data/529/39688taschenkarte.jpgMotul Specific said:Touareg R5 and V10 Tdi must use Motul Specific 506 01-506 00-503 00.
Is this just a carelessly typed sentence?Just to confirm and for you to understand our products don’t comply with VW specs we went through all the testing that VW requires for each one of our products.
