Looks awesome, how much...Just get this unit with backup camera and you will have modernized MK4 with Nav, DVD, Camera, SD capability & other cool features.
http://www.audiosources.net/productshow.asp?bid=28&tid=42&sid=42&id=57
BTW I have their unit in my MK5 so far like it.
Follow the license plate light power wires?Is there a viable path for routing the wires from the trunk area out to (outside of) the bumper?
I installed one on my R32 last year. The wiring exits the car through a grommet at the driver side near the rear sunroof drain exit. It is also clipped into the bumper cover. You will have to remove the carpet piece on that side of the trunk and then you will see where the wiring goes out. I took a few pics, I can post those later today.I already have a camera (and am waiting on the HU). I'm just wanting to know how one routes wires to reach the license plate/outer bumper.
This is probably the easiest way.
I agree. The camera isn't going to draw much current. So there's really no need for a relay.The relay is overkill. All you really need is two diodes...
