Hello all,
I have a 2000 Jetta TDI. Lately I have been noticing a problem where the car seems to be having some idling problems.
Basically, the car normally idles at 800 or 900 RPM. In the past few weeks, it has happened to me 3 times that the idle RPMs are slightly higher, at about 1000-1100. While this is happening, if the car is in neutral and I give it some gas then let off the pedal, the RPMs drop at a normal rate until about 1300 RPM, then drop very slowly down to the higher 1000-1100. Then, if I sit there at this higher idle speed, the car bucks a bit, and the RPMs jump a bit then fall, about every 1-2 seconds or so.
This does not happen all the time, and as I said, has only happened a few times in the past week. At all other times the car is fine. Also, every time this has happened the car has been completely warmed up.
Finally, I did have the timing belt replaced but that was about 12,000 miles ago and haven't had any problems until recently.
Any ideas?
thanks,
matt
Any ideas?
thanks,
matt
