Grasschopper
Hey gang. As we all know the dieselgate payouts are soon upon us and I'm really torn on what to do. My situation is this: 2009 JSW TDI with 138,800 miles on the clock. I've owned this car since Dec 2010 when it had 14k miles on it and I have had done EVERY VW prescribed maintenance thus far....all the DSG services, all the fuel filter changes, just did the timing belt, just did the rear brakes and I have a FrostHeater installed. Car has been paid off for over a year, runs great and I'm getting ~40mpg (bit higher in the summer, lower in the winter).
On Monday I hopped in to head to work and as I was backing out of my garage I heard a loud SNAP!!!! in the front of the car. UM...*** was that? Looking around the car my right front now sits 1/2" lower than the left front...so I'm guessing that the spring snapped. Earlier this year for inspection they found a rear spring was cracked at the end and it had to be replaced. When I ordered those springs I got all 4 but only installed the rears choosing to wait on the fronts until the struts needed replaced because of the design. Dealer said shocks and struts are fine.
So now here I sit a month out from the first decision point. I have a Jeep Wrangler that I've been driving to work, just parked the JSW for now. What do I do with the JSW?
If I'm going to get the spring replaced I might as well do the struts at the same time. And if I'm doing the struts then the strut bearings and might as well do the rears as well. These are original with >138k miles on them after all. But it seems stupid to drop the cash on that (~$600 for the parts plus labor and an alignment) if I'm going to take the full VW payout and give them my car. I was planning on keeping the car, but this wasn't expected and shines the light on the fact that other things I'm not expecting are going to start going bad on a car with >140k miles on it.
My calculated payout is $12,875 if I'm under 140k miles, which I will be for sure at this point. Take the cash and bid the JSW a fond farewell? Keep the JSW and run it into the ground after VW does whatever they are going to do to it?
