Prime after timing belt replacement -off by one question?
u20100509
Spring, Texas, USA
2003 Volkswagen New Beetle 1.9 TDI
2003 Beetle Manual
Is it necessary to prime the fuel system after the timing belt replacement?
The original owner put an aftermarket flywheel on the car so there was no timing mark. I had to use the glow plug and rotate the flywheel back and forth to find the center. Basically I put white paint on the teeth at the end of the stroke when the piston started going down. There were nine marks between them so I put it on 5. Would it hurt anything if it were 1 tooth off? I triple checked it and it was on my mark.
After installing the timing belt and bumping the engine over a few times to check the belts I tried to start the car. It acts like it is running on 1-3 cylinders when it does start. It takes about 10 seconds for it to start. I triple checked the injection pump alignment hole with a camera to make sure the tool went in correctly. It was at the 1 o'clock position and the locking tool went in all the way to the handle.
u20100509
Spring, Texas, USA
Turns out the rough running was the tee connector on the fuel filter not seated correctly.
I'm still curious about the previous two questions though.
