Old August 29th, 2013, 23:48   #1
SyncroS8
TDI(s): Audi S8
Default Audi A6 2.5TDi AKE engine fix - con rod bolt torque spec please
Hello all,
I'm in the middle of repairing an Audi A6 2.5TDi (2001 Quattro Sport Avant) with the 180bhp AKE engine.
It was cheap as the previous owner drove it through a flood and sucked a load of water into the engine and bent 2 con rods. It still ran! The compression figures were off so I pulled the heads. Both front pistons were a good 4-5mm lower down than the other 4 pistons.
Fortunately it only bent the front two rods, the ones that you can get to without having to pull the upper sump off so I've manage located replacements and it's all back together but... I can't find the torque specs for the con rod bolts anywhere.
Come to think of it... I can't find the specs for the cylinder head bolts either. Does anyone have access to a workshop manual for this engine?
I really only need the torque specs for the con rods and heads. The rest is basic stuff and normal torque specs will do.
I've tried searching on here (and around the net) but come up blank.
Thanks in advance.
MG
SyncroS8 is offline   Reply With Quote
Old August 31st, 2013, 11:29   #2
wilharper2000
Con rod bolts:
Renew
30NM
1/4 turn
Threads and contact surfaces must be lubed as well.
Head bolts:
Renew
35NM
60NM
1/4 Turn
1/4 Turn
Sequence looks like (Timing gear on the left)
7 1 3 5
6 4 2 8
wilharper2000 is offline   Reply With Quote
Old August 31st, 2013, 23:29   #3
SyncroS8
TDI(s): Audi S8
That's great
MG
audi A6 2.5TDI flat spot tunneler TDI 101 0 November 22nd, 2010 05:55
audi a6 2.5tdi v6 heads off how to please zorgman TDI 101 0 October 14th, 2009 08:35
Audi A6 2.5TDI question totopz TDI 101 5 January 17th, 2007 12:11
Audi A6 2.5TDi 103KW marius_b Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 7 April 16th, 2003 07:52
Audi A6 2.5Tdi V6 oil service reset. Keith Davis Other VW Group TD(I)s 3 December 10th, 2001 03:00
Page generated in 0.10019 seconds with 11 queries
[Output: 56.92 Kb. compressed to 51.81 Kb. by saving 5.11 Kb. (8.97%)]
