Old June 30th, 2009, 14:56   #1
freegeek
TDI(s): ibiza
Default N75 logs on vag-com
Does anyone know what block and position to log for the N75 signal?
freegeek is offline   Reply With Quote
Old June 30th, 2009, 16:03   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Desired Map shows you what the N75 is trying to accomplish.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old June 30th, 2009, 17:06   #3
DanG144
Probably measuring block 11 field 4.
If you can tell me which label file xxx.lbl your VCDS opens when you go to ENGINE and MEASURING BLOCKS, then I can tell you for sure.
Dan
Old July 1st, 2009, 05:31   #4
freegeek
TDI(s): ibiza
Great, I found that it as suggested at block 11 position 4, it seems to be quite different from my petrol 1.8T values.
Does anyone have a log of what it should look like?
Page generated in 0.08734 seconds with 10 queries
[Output: 57.40 Kb. compressed to 51.00 Kb. by saving 6.41 Kb. (11.16%)]
