1998 TDI into a Toyota Pickup
adammtb
Asheville, NC
none right now
Hello everyone. I'm thinking of dropping a TDI into my 1986 toyota pickup. I've got a lead on a 1998 TDI jetta that was wrecked for a $1000. The guy says the motor spins freely but can't hear it run cause the fuel tank was removed. The car has been sitting since 2005.
Anything in particular I should look for when I go to check it out?
Thanks so much
Spulen81
Warners, NY
Well you could bring a small can of diesel and run a hose to the pump to try it out. Check and see if the timing belt is intact. I would pull the valve cover at the very least and look for evidence of water/rust. But at that price its pretty much worth it no matter what.
