K Khansen720 New member Joined Sep 20, 2018 Location Michigan TDI 2014 jetta dsg Nav. Premium Oct 5, 2018 #1 Hi found some nice used winter tires on craigslist and was just curious if I could run 215/55R17 tires without issue.
Gilty_one Veteran Member Joined Jul 2, 2007 Location Warman, Saskatchewan, Canada TDI 2016 Touareg Execline 3.0 V6 TDI; 2012 Jetta Highline TDI Oct 5, 2018 #2 Should work... but make sure you have the right load for those tires (minimum is 91)
K Khansen720 New member Joined Sep 20, 2018 Location Michigan TDI 2014 jetta dsg Nav. Premium Oct 8, 2018 #3 They are the correct load I'm just worried about fuel mileage loss and possible rubbing.
0 06bluebeetletdi Veteran Member Joined Sep 30, 2012 Location Middlesex, NC TDI '14 Passat TDI SEL and '13 Beetle TDI Oct 8, 2018 #4 That is beetle/passat size. Jetta/golf are 225/45r17. The tire is 1.3” in diameter larger than a jetta tire.
