1dieselsteve
Be careful with the cheapest.... Wouldn't wanna do it twiceThanks for the input everyone.... I'll go with whatever is the cheapest at the time
From what I've seen the kits I have mentioned are all of good build. I held a rawtek the other day and it's very nice but also expensiveBe careful with the cheapest.... Wouldn't wanna do it twice
^^^^2nd I've seen on here so far get taken out?
As my egt probe and vacuum actuator are broken, I think about getting an used CBBB Turbo.
Can anybody confirm that the EGT probe from the CR170 works with a CR140 ECU?
Thank you! Turbo ordered.Confirmed.
How much air was flowing over the core for this test? Something like sitting on a dyno with a big fan? or a roll on starting at 60? Ambient temp? And I assume this is the stock tfsi IC, not the S3? or are those the same?These comparisons were done with the 2.0TFSI & the S3. This should give us a baseline. I think are rpm's are too low to see that much of temperature difference.
8 Hours is not bad @ all. Less than a month away!! Your going to love it.My car is getting CR170 in early June.
My mechanic quoted me 8hr to swap the turbo / install HP EGR delete race pipe and tune to Stage 3.
It is different. I changed my long coding around to where I can hold down the TC button and it will turn stabilization off after TC. This can be done with vag com. Simply go to the APR website and paste your long code in, hit generate, and the paste and save your long code into your car... here is the link:Is ESP the same as TCS?
Sorry, should have said TC. The switch says ESP on it, but like stated above, it only disables TC. Or more likely TC is still on, but at a reduced level. Either way it makes a big difference on the butt-dyno. I haven't messed with the ESP long coding at all.Is ESP the same as TCS?
http://www.wagner-tuning.com/Competition-Intercooler-Kit-VW-GolfJetta-6-20-TDI_p_104.htmlhow much is the wagner intercooler?
