iamatt
didn't do anything to the tdi but I did pick up an 99 E300 turbodiesel
I changed my air filter last week at 37k. It was pretty dirty, but isnt the factory interval 40k mile for the ALH?bikeprof said:Hmmm, I have my air filter on a 10K schedule, there is a LOT of dust where I reside .
You may not..., but 23K, that is a LOT!
Yes it is... Mine was so black and nasty, there is no way I would have taken it to 40k. Filters are cheap, so I'm changing more frequently.david_594 said:I changed my air filter last week at 37k. It was pretty dirty, but isnt the factory interval 40k mile for the ALH?
Pros/cons of the 195 degree vs. 189 degree tstat?david_594 said:Replaced the coolant hose for the webasto that was leaking and swapped out the stock thermostat 189 degree thermostat for a 195 degree one.
I pulled the thermostat housing and very little coolant spilled. Was pretty excited untill I got the thermostat out only to have all the coolant behind it pour everywhere.
Did you learn the procedure through reading the How To's on the board in 101?MethylEster said:Cleaned my intake. It was coked up to where only a one inch diameter opening was left.
So the bigger manifold made it louder and and decreased low-end response?IndigoBlueWagon said:Put a stock intake manifold on IBW, temporarily, so I can use the PD150 intake on the Golf. I was surprised at how different it is: quieter, more low end response, more smoke, higher EGTs. Just what you'd think. So now I can look forward to the reverse on the Golf, especially the lower EGTs.
