98JettaBioDiesel
My 98 (only 410k miles so far) has intermittent key fob operation. Great when it works but often no response at all (more often in the morning but either before or after driving and doesn't seem temperature related nor 12V car battery related).
My 2x CR2016 batteries are strong, measuring 3.25V each. Recently replaced the worn fob housing which at first I thought solved the problem (better mechanical contact to switches) but turns out no change.
So, I suspect the car end is intermittent - anybody know where that is and if it can be replaced? (or other ideas)?
