cevans
TDIClub Enthusiast, TDI Parts Ninja Vendor , w/Bus
Update your TDI's performance with these great parts!
Get a set of FIRAD Upgraded Injector Nozzles already mounted to rebuilt, calibrated
and tested injector bodies through our injector upgrade program! You’ll get a set of
injectors delivered that are are fully ready to be installed, and you send your old
injectors back to us later!
View Product
Our latest shipment of FIRAD Nozzles has just arrived! These are the highest quality
nozzles made in FIRAD’s own facility in Italy. We have stock replacement 706 nozzles,
the best selling 520 nozzle and the 502 great for upgraded turbos and aggressive tunes in stock now!
View Product
The Mk5/6 chassis is a fairly nice riding platform, but steering response is lackluster.
The S3 control control arm bracket upgrade uses a stiffer bushing and takes some of
the steering slop out. If your Mk5/6 has over 100k miles, it's time to refresh this
component, and the S3 bracket option is a great choice!
View Product
Replacing rear axle bushings on a Mk4 is not a fun job, but it makes it a great time to upgrade.
You don’t realize how much damage your rear axle bushings were doing to your ride quality
and handling until you swap in these Seat bushings. The difference is night and day!
View Product
Refresh the most important components on your Mk4 all at once and also upgrade to the
TT control arm rear bushings at the same time with this all-in-one unit!
View Product
It is true that poly upgrades can often really hurt ride quality, but, we find that they are
a perfect fit for sway bar components that develop clunks with normal bushings.
These are an inexpensive and easy upgrade.
View Product
SUSPENSION UPGRADES
The KONI Rebate is BACK for a limited time! This year KONI introduced a new line of
shocks & struts - the KONI Special Active. Grab a set of the latest in ride control and
get a nice chunk of change back in a rebate!
View Product
View Product
View Product
View Product
View Product
View Product
View Product
SUSPENSION UPGRADES
View Product
