ymz
- Joined
- May 12, 2003
- Location
- Between Toronto & Montreal
- TDI
- 2003 Jetta TDI Wagon, 2003 Jetta TDI Wagon
Sounds like a Relay 109 ("Main Power Relay") problem... the early ones are known to be intermittent... if you don't get any of the dashboard lights coming on, that's the problem... The VW part number is 1J0-906-381-A...economicuskp said:When starting my car, the glow plug indicator sometimes comes on (about one in ten times maybe) and otherwise does not. When it does not come on, the car obviously won't start.
(Also comes as 130-906-381-A)
It's found above the clutch pedal, just in back (to the right) of the fuse panel...
Yuri.
