That WWII parts place has run out of those oil separators, however, I found this one for $40.00. Anyone think it will work? Oil Separator P/N OIL-BS5/8
I actually used a Fram HPG1 racing fuel filter and clear tubing to hook it up. The inlet tubing was coated after 2000 miles. I mounted it up by the radiator. The outlet is still clear.
