ForestHill
So, all the articles about ULSD seem to imply "cleaner emissions" with ULSD. But is this true for a pre-'07 car like my '04 TDI?
__. That's right. If you take an ordinary diesel car built in the last 10 years, it will probably be a good bit cleaner on ULSD. There will be what's basically a total reduction in SOX emissions and there's a knock-on effect for HC emissions as well. But the big effect will be on particulates. Without the molecules of sulfur to act as a precipitate core, there will be less formation of particulates. That has two good effects; big particulates are "soot" and we've all lived with too much of that in our cars for years, small particulates can be so small that they are invisible or near-invisible. These are the ones that will penetrate deeply into your lungs and resist the normal mechanisms that lungs have to clear them.wny_pat said:Cleaner, but no where as clean as post "07s.
__. My experience has been just the opposite, for my '02 Jetta (RIP) and MzLauraLee's waggin (but MzLauraLee uses B20 from the Pentagon place so it's not exactly the same).TomatoPie said:(snip) I get more diesel stink. (snip) Is it the ULSD? (snip)
Same here...I've noticed far less smoke at WOT and less stink from both of my TDIs (02 Golf, 05 PD Jetta Wagen). I've noticed virtually no change in MPGs with ULSD compared to rotgut LSD. If there's any difference at all in MPGs, it's too small to notice and I'm not going to worry about it.Brock_from_WI said:I have noticed less smoke on WOT and less smell in our garage now that we are on ULSD.
Same here.. First tank with the green sticker, and I am getting a diesel exhaust smell in the cabin. I have to turn off the air, and close the vent with the recirculate button for it to go away.TomatoPie said:Since my retailer started with ULSD, I have noticed 2 things. First, a drop of 1-2 mpg. That could be due to colder weather, though.
The other is pronounced: I get more diesel stink. Before, I would pull into my garage (head first) and when I got out, no stink. Now, there is a pronounced smell of lingering diesel exhaust every time I exit the vehicle.
Is it the ULSD? The car runs fine, as always. 2005 Passat TDI.
ForestHill said:ULSD emissions any cleaner in pre '07 cars?
Think you have a different problem - exhaust leak.Dunno513 said:Same here.. First tank with the green sticker, and I am getting a diesel exhaust smell in the cabin. I have to turn off the air, and close the vent with the recirculate button for it to go away.
Do you really believe that using ULSD somehow actually CLEANED any soot out? How do you suppose that happened? LOLThermo1223 said:Personally it took about 2 tank for it to finally clear all the soot out of my pipe. I think that has a lot to do with my short trips to work but I try to get her on the highway every weekend when possible.
Til I gradually cleaned out my own tailpipe and tank from LSD yes. I build quite a bit it seems just putting around town.DieselSmoker said:Do you really believe that using ULSD somehow actually CLEANED any soot out? How do you suppose that happened? LOL
Dorf your numbers seem about correct with the 10%, or at least more believable. In my Cummins, I can still blow thick black clouds of smoke in the right conditions, and they don't seem to be any thinner...10% I could be missing either way..
