colorobo2002
I'm in the middle of the fuel injection pump replacement. A little background: i'm using the metalnerd tools, and have done and undone the install 3-4 times (the first 3-4 times the timing marks didn't all align, so i had to remove/loosen the belt/2 pulleys and redo).
Here is where I screwed up... on the 4th time, i tried to rotate the engine (with the camshaft locking plate installed AND the car in gear, fuel injection pump locking pin WAS removed). While beginning to rotate the engine, I heard a snap/shearing sound, which i presume was the locking plate, as it is slightly twisted and cracked. Yup, i screwed up, and hoped for the best...
So i removed the belt/pulleys and redid the install, but this time I got a very firm resistence when i tried to rotate the engine (the proper way with no plate and not in gear). I am familiar with how much resistence was present the first 3 times i rotated the engine, so i am confident that the resistence i feel is not normal.
So again, i removed the belt/pulleys and turned each part of the motor individually and they all seem to rotate fine on their own, with no resistence.
Any thoughts of what i have done? Why am i getting this resistence under pressure, when I have removed the cam locking plate, pump pin, and taken it out of gear?
