Hello fine folks at the TDI club. It looks like I have to ask for help on the next round of trouble shooting. After following all the test procedures in this thread Still no success. Here's where I'm at:
New lift pump modified a la DanG and LCR. No luck. New Tandem pump
(after testing flow thru return line), still same problem. Pulled EGR, cleaned and reinstalled, also ran it with EGR unplugged. Pulled shutdown/anti-shudder valve connector, no difference.
FWIW, car has 96K miles, running biodiesel, DSG trans, new TB by dealer at 90K. The car shows no codes on my ScanGauge.
The original problem began as my wife was driving out of a large parking lot. Driving 10 -15 mph it just quit on her and she coasted to the side. I came out and got it to start and figured out that if I kept the revs up it would drive just fine so I got it home.
Now two fuel pumps later, just like my original issue, it still cranks for several minutes then just barely starts to run while cranking, then by slowly pushing on accelerator it will catch and run at 1800-2000 rpm's very smoothly. After a couple minutes at these high rpm's it will idle roughly within a few hundred rpm up or down then just dies like it is out of fuel.
So what do you think is my next course of action? Would the car still run if the TB slipped one tooth? Could the MAF be NG? I was thinking of checking the cam for wear on an injector lobe then checking injector connections then remove injectors to visually check. Is there any logic to this?
Thanks in advance for any help and advice.
