newtdiowner123
Hi guys. A few days ago my engine randomly shut off followed by a battery light on the dashboard. It hasnt started ever since. It cranks, but no start. What can I start with? I ran an autoscan and this is what I got.
Thanks in advance
VIN: WVWZZZ1KZ7W247104 License Plate: UY
Mileage: 279110km-173430mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 69 72
VIN: WVWZZZ1KZ7W247104 Mileage: 279110km-173430miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 021 KH HW: 03G 906 021 AN
Component: R4 1,9L EDC G000SG 9245
Revision: --H06--- Serial number: VWZBZ0G0591679
Coding: 0000071
Shop #: WSC 01392 785 00200
VCID: 6FECEB207E9D0D3CF1-803A
4 Faults Found:
005658 - Glowplug for Cylinder 4 (Q13)
P161A - 000 - Open Circuit
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Temperature: 3556.0°C
Bin. Bits: 00001111
Ign. Timing: 1.8 °BTDC
Inj. On Time: p ms
005648 - MIL Control Circuit
P1610 - 000 - Open or Short to Plus
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Inj. On Time: p ms
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Inj. On Time: p ms
000800 - Engine Speed Sensor (G28)
P0320 - 000 - Intermittent - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 279112 km
Time Indication: 0
Date: 2000.00.00
Time: 21:50:23
Freeze Frame:
RPM: 0 /min
Voltage: 0.10 V
(no units): 0.0
Temperature: 3760.8°C
Bin. Bits: 00001111
Load: 261.2 %
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021121
VCID: 73E4E75012B529DC15-8026
2 Faults Found:
00668 - Cruise Control Switch (E45)
002 - Lower Limit Exceeded - Intermittent
01424 - Radio Louder
012 - Electrical Fault in Circuit
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 GA HW: 1K0 820 047 GA
Component: Climatic PQ35 141 0909
Revision: 00141027 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 69D885384079E30CAF-803C
1 Fault Found:
01044 - Brake and Parking Brake Warning Light (K7)
004 - No Signal/Communication - Intermittent
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 AD HW: 3C0 937 049 AD
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004772904
Coding: 088B8F2700041500471400001400000000097B075C0001
Shop #: WSC 01287 785 00200
VCID: 6BD4FF304A85F11CDD-803E
Subsystem 1 - Part No: 1K1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 260307 020 0501
Coding: 00038805
Shop #: WSC 01287
2 Faults Found:
02394 - Parking Light Rear Right (M2)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 235
Mileage: 277048 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Content: 92.0 mm
Mileage: 1350 km
Mileage: 1350 km
OFF
Mileage: 1360 km
Mileage: 1350 km
00912 - Window Regulator Switch; Rear Right; Driver (E55)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 246
Mileage: 278867 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Content: 75.5 mm
Mileage: 1360 km
Mileage: 1350 km
OFF
Mileage: 1360 km
Mileage: 1360 km
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 37 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD14LVFZ
Coding: 0013111
Shop #: WSC 01373 785 00200
VCID: 3D7001686471AFAC33-8068
Subsystem 1 - Serial number: 6332MSME17615B59G
Subsystem 2 - Serial number: 6342MSME180D232EF
Subsystem 3 - Serial number: 6352QSME206B1101%
Subsystem 4 - Serial number: 6362QSME22323C114
1 Fault Found:
00532 - Knock Regulation 1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74E6E44C17BB2EE40C-8020
No fault code found.
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 863 B HW: 1K0 920 863 B
Component: KOMBIINSTRUMENT VN4 8212
Revision: V0007000 Serial number: VWZBZ0G0591679
Coding: 0005103
Shop #: WSC 00011 888 06946
VCID: 2A5A3A3485FF281466-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 210307F2002134
Coding: 3D3F434007001002
Shop #: WSC 00940 218 85487
VCID: 2F6C2B20BE1D4D3CB1-807A
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No: 1K0 920 863 B
Component: IMMO VN4 8212
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0987
Coding: 0000180
VCID: 387E107C4B538A84E0-806C
2 Faults Found:
00608 - Ignition Output 3
014 - Defective
00928 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 005 0912
Coding: 0000144
Shop #: WSC 01392 785 1012552
2 Faults Found:
02325 - Position Sensor for Rear Seat Height Adjustment (G439)
01328 - Door Control Module; Driver Side (J386)
014 - Defective
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H16 0070
Revision: 3A002001 Serial number: 00000109751446
Coding: 0100000200000000
VCID: 2E52362479174434BA-807A
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Component: Tuer-SG 005 0913
Coding: 0000144
VCID: 397815787059938C1F-806C
4 Faults Found:
01846 - Temperature Sensor for Heated Seat; Rear Left (G94)
000 - -
01552 - Motors for Central Locking; Save [Safe?]
014 - Defective - Intermittent
008 - Implausible Signal - Intermittent
End-------------------------(Elapsed Time: 01:40)--------------------------
Thanks in advance
Coding: 0000071
4 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Inj. On Time: p ms
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Inj. On Time: p ms
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 274371 km
Time Indication: 0
Date: 2000.00.00
Time: 08:37:24
Freeze Frame:
RPM: 147 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Inj. On Time: p ms
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 279112 km
Time Indication: 0
Date: 2000.00.00
Time: 21:50:23
Freeze Frame:
RPM: 0 /min
Voltage: 0.10 V
(no units): 0.0
Bin. Bits: 00001111
Load: 261.2 %
Revision: 00H11001
Coding: 0021121
2 Faults Found:
1 Fault Found:
Coding: 00038805
Shop #: WSC 01287
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 235
Mileage: 277048 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Content: 92.0 mm
Mileage: 1350 km
Mileage: 1350 km
OFF
Mileage: 1360 km
Mileage: 1350 km
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 246
Mileage: 278867 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
OFF
Content: 75.5 mm
Mileage: 1360 km
Mileage: 1350 km
OFF
Mileage: 1360 km
Mileage: 1360 km
Coding: 0013111
1 Fault Found:
Coding: 0000042
Coding: 0005103
Coding: 0000180
2 Faults Found:
014 - Defective
Cannot be reached
Cannot be reached
Cannot be reached
Address 56: Radio
Cannot be reached
Coding: 0000144
2 Faults Found:
014 - Defective
Coding: 0000144
4 Faults Found:
000 - -
