benIV
- Joined
- Oct 25, 2009
- Location
- Southeast NC
- TDI
- 2003 PG 5m Jetta GL Sedan, 2003 RS 5m Jetta GLS Wagon (Golf Variant)
i knew it, those jerks
Last I "heard" LSD and ULSD were produced primarily by hydrotreating/hydrocracking which net results in smaller molecules than going in (the cracking), and where hydrogen displaces sulfur & nitrogen molecules in the output which is usually jet fuel, diesel, and some cut of gasoline (provides high octane). So more of the aromatic compounds getting treated for ULSD will get stuffed with hydrogen. Basically, with ULSD there should be less/fewer aromaticsThe 'ultra low' obviously has less sulphur ppm than the 'low sulphur' which means that the ultra low has less lubricity than the low sulphur of which the process in which they use for the u/low takes it out..............its supposed give a cleaner burn and have a slightly higher cetane number but it probably carries more aromatics to compensate for the prolonged cracking process to reach the lower ppm of sulpur..........Aromatics create more smoke output (go figure!) a better way to do it would be to do what they do here in the UK and Europe and just add around 5%/10% ester but Oops wait thats biodiesel isn't it................................my bad!!
I'm not sure if ULSD is suppose to have higher cetane number vs LSD. The process that is used to go from LSD to ULSD actually decreases the energy content of the fuel. I'm not an expert ... but this is a quote from Shell's website:
Q7. How does ULSD fuel affect the power and fuel economy of existing diesel cars, trucks and non-road engines and equipment?
A7. Under typical operating conditions, there should be no noticeable impact on overall power using ULSD fuel. Fuel economy may be reduced slightly because the process that removes sulfur also can reduce the energy content of the fuel.
Might help explain why I get better mileage on B100 than on 40 cetane pump diesel (ULSD).I'm not sure if ULSD is suppose to have higher cetane number vs LSD. The process that is used to go from LSD to ULSD actually decreases the energy content of the fuel. I'm not an expert ... but this is a quote from Shell's website:
I think if there is any concern over fuel temp. it would be at the rail where the fuel is pressurized. Pressure=heat.Do you really think that 100 degrees F is a high enough temperature to be concerned about it? That's cooler than the water in the average spa!
Deosn't bio have a higher flashpoint than ULSD (and thus the issues with DPF's)?
The issue is not with the DPF itself, but what happens to the fuel during a regeneration. Raw fuel is injected into the combustion chamber, but is not combusted until it reaches the DPF. Raw fuel can splash on the cylinder walls and can be "scraped" down into the sump where it mixes with the engine oil. Pure ULSD is relatively harmless, but biodiesel can turn into a real mess in the tiny oil passages.From what I have read extensive testing has been and is being done in regards to how BD affects the DPF. Presently there is no correlation with BD and premature failure of the DPF. From what little data I've read the byproducts from burning DPF have high oxidative properties and therefore burn off easier.
In my unqualified opinion my only worry with BD would be who well it survives the constant trips around the fuel systems (Tank>>common rail>>back to tank..repeat).
Yep. I read about the oil dilution (& ZDDP) issue as well.The issue is not with the DPF itself, but what happens to the fuel during a regeneration. Raw fuel is injected into the combustion chamber, but is not combusted until it reaches the DPF. Raw fuel can splash on the cylinder walls and can be "scraped" down into the sump where it mixes with the engine oil. Pure ULSD is relatively harmless, but biodiesel can turn into a real mess in the tiny oil passages.
Anyway, the rule of thumb is to use a very low concentration of biodiesel -- B02 or B05 is probably okay, but B20 or higher and I'd strongly recommend sharply reducing the oil change interval.
To go along with you report I too contacted Shell, Chevron, ARCO and Conoco/Phillips 76. All indicated they purchase their additive from a third party and all stated that the additive they add is made 'just' for them. One, don't remember which' said the maker is one of the largest in the business.So before anyone gets their undies in a bunch, the idea of using additives is one of those topics that will incite a "religious war". What I have below is not to incite but inform.
VW says no additives. That is convenient for them to do. No decisions needed, no analysis, problem solved. Yet, in the past, VW was in bed with Stanadyne and I won't go and pontificate on that relationship yet I find it to be an interesting one, considering their current stance.
I went and did some research today that I found to be interesting. It is a given that US diesel fuel has far less lubricating properties than European diesel fuel and that the cetane rating is not as high. So, I went and printed out a bunch of MSDS's and did some comparing.
For diesel fuel, I picked on ExxonMobil, Citgo, Speedway/SuperAmerica, Hess, BP and ConocoPhillips. In reading the reports, I found that they list the following chemicals at some level in their fuels: #2 Diesel fuel, Ethylbenzene, Napthalene, Cumene/Isopropylbenzene, Trimethylbenzene, Nonane, Xylene. Mind you that not all the listed chemicals are present in everyone's fuel but one, Citgo, listed the most.
Now on to the more popular additives. PowerService lists: Ethylbenzene, Napthalene, Trimethylbenzenes, Xylene, and Vinyl Acetate (winter). Stanadyne lists: Petroleum Naptha, Napthalene, Trimethybenzenes, and Stoddard Solvent (White Spirit). Opti-Lube XPD lists: Ethylbenzene, Petroleum Naptha, Napthalene, Cumene, Trimethylbenzenes, Xylene, Propylene Glycol Ether, 2-Ethylhexyl Nitrate.
Now, if you compare both the additives and the base fuels, they both list the same chemistries, more or less. This, of course, does not list anything that does not have to be put onto the MSDS that may be present, such as whatever PowerService's "SlickDiesel" is.
So, with this, all additives are doing is putting into the fuel what may already be there, especially the chemicals that have to do with cetane rating improvement. I would honestly expect the refiner to add chemicals to trim and tweak a batch to come into spec using the above chemicals. Now I really don't understand VW's stand on not using additives unless it is used as a quickie dismissal of warranty costs hoping someone will admit to using an additive that has no chance of harming the engine. That is akin to saying that I won't warranty the product you bought from be because you did not use Brand X distilled water but you used Brand Y distilled water yet chemically they are both exactly the same, came from the same plant, but Brand Y was cheaper by $2.00 in the store.
2-EthylHexyl Nitrate (2-EHN), is a cetane improver. The cetane level (higher is better) is a measure of how well the fuel self-ignites. Since the newer CR engines use multi-pulse injection, this will help the engine fire smoother and be quieter.What is 2-EHN? And what is nailing at cold start?
This information is exactly what the fellow at Conoco/Phillips 76 told me. I mentioned to him that my TDI seems to sound significantly quieter when I use 76 diesel. He laughed and said thats because of the high Cetane level (53.7) of their diesel.2-EthylHexyl Nitrate (2-EHN), is a cetane improver. The cetane level (higher is better) is a measure of how well the fuel self-ignites. Since the newer CR engines use multi-pulse injection, this will help the engine fire smoother and be quieter.
The "nailing" I am referring to is the sound of a single shot injection as the fuel combusts and suddenly slams everything - hence the classic diesel sound. It seems that my car will do single shot when cold and then go to multi-pulse once it warms up but so far, all has been quiet.
Hope that helps.
Wowsers!!! Now only if the goofballs in D.C. get their act together, raise lubricity requirements, raise minimum cetane to at least 50, and get rid of boutique fuels (both gas and diesel. Personally, I would like to tell CARB to shove it!!!This information is exactly what the fellow at Conoco/Phillips 76 told me. I mentioned to him that my TDI seems to sound significantly quieter when I use 76 diesel. He laughed and said thats because of the high Cetane level (53.7) of their diesel.
Wow! 53?! We have a Conoco I drive by 2-3 times per week. I never thought to give them a try, mainly because they're $0.25/gal higher than Murphy (Walmart) that claims a Cetane of "around 50."This information is exactly what the fellow at Conoco/Phillips 76 told me. I mentioned to him that my TDI seems to sound significantly quieter when I use 76 diesel. He laughed and said thats because of the high Cetane level (53.7) of their diesel.
You're right. Reading this thread, it's pretty clear that there are major regional differences in fuel...assuming the pump sticker is even accurate to what's in the ground.Wow! 53?! We have a Conoco I drive by 2-3 times per week. I never thought to give them a try, mainly because they're $0.25/gal higher than Murphy (Walmart) that claims a Cetane of "around 50."
I've never heard of a station give such a specific Cetane rating (i.e. "53.7"). That level of specificity sounds like they have actually done some testing. I'll give it a shot and see if I can notice a difference.
Of course, this is in Alabama, not Cali, so it might be different here.
Here is a copy of my post where I explain how and where I obtained the Cetane number to which you speak.Wow! 53?! We have a Conoco I drive by 2-3 times per week. I never thought to give them a try, mainly because they're $0.25/gal higher than Murphy (Walmart) that claims a Cetane of "around 50."
