benmarks
I have a 2000 Jetta and my glow plug light is flashing. It has been flashing for a while. I took it the the dealer a few months ago and they replaced my brake switch due to the TSB, but no change. I wouldn't let them touch any non-TSB issues. I just had a bunch of other work done here in Portland (a strong recommendation for Fix Um Haus) and they tried multiple brake switches and some other approaches (checked the relay, harness and plugs,) but still no change. I needed the car back before this got resolved, and I know they're still bugged by it, so does anybody else here have any ideas? The error code that keeps re-appearing is for the brake switch. Sometimes after the switch is swapped, the light will stay off for 10 minutes, but it eventually returns and, once it does, it comes on immediately after ignition from that point forward. After performing a search, I noticed a few people resolving this issue by replacing blown tail lightbulbs, but all of mine are working. Could I have put in the wrong bulbs? I haven't found any other causes or solutions.
Any ideas?
Any ideas?
