arazvan2002
S2 SRE clutch cover would be better matched with a better plate. The organic option from SRE holds 520Nm+. I more then you can gain from your turbo.Put 240mm S2 clutch on my 00' passat afn with gtb2056 and 0.280 nozzles.
It is slipping relatively easy from third gear and up. It is not very much better than my old stock 5speed dmf clutch. Any thoughts? Is there something I have done wrong or am I already beyond this clutch limit? SRE will help me out?
Although the pedal would be stiffer. A little hard to drive it in the city for long time.
883082999707 is the cover for S2 3B engine.
Sent from my VF-1397 using Tapatalk
