TheArchitect
Hi,
The brakes on my golf are useless, had a look and the usual vacuum line was split so i replaced that however this hasn't changed much.
The brake pedal is solid and the abs does seem to work. When I popped off the vacuum line there is suction so the pump should be working fine.
Any ideas where I should look next as all the threads I could find when searching were all resolved by the replacement of the usual pipe.
Many Thanks
Many Thanks
