Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > Non VW Group Diesels
Non VW Group Diesels This section is for discusion of Non VWGroup Diesels.
Old May 23rd, 2018, 06:09   #691
kooyajerms
grocery getter
kooyajerms's Avatar
Not me, I’m running all that expensive oem/ZF trans service, diff, and trans case fluid. Saving containers and using FCPEuro’s warranty program makes the cost closer to $335 instead of $600. I just need to preload the next service and keep items on hand and ready to return the service items. All legit, and confirmed multiple times by reps in different venues.
Purchase initial kit and fluids -$600
Perform service and drive x miles
Purchase another identical set - $600
Perform service and return all used parts and fluids -$75
-$1275
Receive credit back to card for $600
-$675 for two full service kits (obviously trans miles vs what’s needed for diff and trans case is different)
-$335 cost per kit if you are willing to do that legwork.
kooyajerms is offline   Reply With Quote
Old May 23rd, 2018, 12:07   #692
jck66
jck66's Avatar
I wonder if some of the transfer case issues stem from the fact that (at least on the E60 and F10 chassis) you need to lower/move the exhaust to even access the transfer case, and there's no drain so you have to pull it out, invert, refill, and re-install. Then put the exhaust back. Oh, and then have the dealer tell the car's ECU about the replaced fluid. So maybe lots of owners just blow this maintenance off until the thing fails.
FWIW, a (well-respected, well-known, not on tdiclub) BMW guru recommends 50k fluid changes. I am guilty of holding off with a fluid change on my wife's car (currently at just shy of 90k) but will have to bite the bullet at some point. Cheaper to do the maintenance.
jck66 is online now   Reply With Quote
Old May 23rd, 2018, 12:27   #693
dmanb2b
Originally Posted by tomo366 View Post
The Wagons are only available in Xdrive.....so what do you do...
Sorry, missed the wagon part. May not be great on MPG, but I'd go with an x5d if I needed the wagon space. That drivetrain is pretty solid.
dmanb2b is offline   Reply With Quote
Old May 25th, 2018, 19:33   #694
gcodori
When I was researching my TDI replacement I was told that the x-drive can be partially "fixed" by unbolting the front driveshaft and removing it thereby converting it to RWD. I think there was a sensor to unplug, and it threw no codes. Drove normally this way. This was stated by owners, but a pinch of salt may be needed.
Granted, this was on the x5 forums, not the 3 series cars. Same units?
Sent from my SM-G935V using Tapatalk
gcodori is offline   Reply With Quote
Old May 26th, 2018, 03:00   #695
Don't think we do. I'll look into it.
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old June 7th, 2018, 17:12   #696
PeteZ06
TDI(s): E320 CDI
Theres a shop in WA that converted their xdrive to RWD only... I contacted them a few months ago because I saw their car on a dyno spinning only the rear wheels and he said they just unplugged the trasnfercase servo motor with the engine off.
'14 BMW 535D RaceChip Tuned
'14 BMW 328xi
'03 4Runner Lifted and fully armored
'08 Suzuki GSX1300BK Full pipe and tune..200+hp
PeteZ06 is offline   Reply With Quote
Old June 8th, 2018, 07:01   #697
dmanb2b
Dudmd is the shop. Not sure if that conversion was for everyday driving though. His d is badazz. Pulled on a GTR at the strip although couldn't keep up in 1/4mi. Still not bad, sub 13sec car in full size sedan
http://www.dragtimes.com/BMW-535d-Timeslip-29799.html
Old June 8th, 2018, 07:25   #698
German_1er_diesel
German_1er_diesel's Avatar
TDI(s): BMW 118d
That's not bad for a 530d with a big intercooler and not much else.
I wonder how a stock European 535d or 550d would do here.
Still find it confusing that BMW names their diesels differently for North America.
BMW 118d hatchback
German_1er_diesel is offline   Reply With Quote
Old June 8th, 2018, 10:44   #699
jck66
jck66's Avatar
I noticed that on the dudmd video too - thought maybe I had seen it wrong. I was watching at work though so I didn't spend a lot of time on it.
@German_1er, I call it idiotic too. Marketing folks would name the car "susan" if they thought it would sell a few more units.
Old June 11th, 2018, 21:21   #700
2.2TDI
TDI(s): .
Don't worry, the badging on the 530d went from 535d to 540d on the new model... Talk about confusing... But I suppose the reason they did that is to compete against the 540i since price for both 540i and "540d" are in the same range, with the diesel costing 1500 extra... If you left it at 530d in NA and saw the price difference between a 530i and 530d, no one would buy the 530d... (a "540d" is 7550 more then a 530i)
Same thing with the 320d...market it as the 328d so it competes against a 328i and people don't see that it's really a direct competor of the 320i...
Smart marketing...
2.2TDI is offline   Reply With Quote
Old June 11th, 2018, 23:27   #701
German_1er_diesel
TDI(s): BMW 118d
They probably make the diesels more expensive in North America relative to the gassers because they sell not as many of them.
German pre-tax prices:
530e:
47,058.82
520i: 41,092.44€
530i: 44,861.85€
530i xDrive: 49,806.72€
540i: 51,428.57
540i xDrive: 53,613.45
M550i xDrive: 72,521.01
520d manual: 40,627.27
520d auto: 42,563.03
520d xDrive: 44,705.88
520d ED edition: 42,773.11
525d: 46,218.49
530d: 48,571.43
530d xDrive: 50,756.30
540d xDrive: 56,050.42
M550d xDrive: 73,109.24
Technical data:
BMW 118d hatchback
Old June 13th, 2018, 14:36   #702
Mk4tdi02
TDI(s): 02 Golf TDI
Hey guys, looking at a 2011 X5 diesel, had my alh golf but blown clutch now and 400km later, think it's time for another diesel. Are you guys happy with your X5 diesel and would you buy again. thank you.
Mk4tdi02 is offline   Reply With Quote
Old Today, 06:38   #703
dmanb2b
the e70 x5 seems to be a really solid platform with quite a few examples at the 200k mi mark. However, do be ready for maintenance items, such as vacuum lines, carbon cleaning (less prone on x5 than 335d), harmonic balancer and valve cover gasket, SCR tank issues. I have a 335d and would definitely buy an '09-'13 x5 in future.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
jck66
TDIClub Secret Society of Benz Owners (SSBO) cevans Non VW Group Diesels 618 February 11th, 2018 06:40
BMW 335d owners Capt. Common Rail Non VW Group Diesels 38 January 8th, 2017 19:59
--::Polo Cult Society::-- Mosdef Other TDI/Diesel Picture Gallery 0 November 14th, 2002 11:12
Any BMW owners around here? D-Dawg Non VW Group Diesels 8 January 20th, 2001 09:13
Any BMW 525tds owners out there? dave525tds Non VW Group Diesels 6 April 4th, 2000 02:40
Page generated in 0.17278 seconds with 12 queries
[Output: 122.52 Kb. compressed to 103.35 Kb. by saving 19.17 Kb. (15.65%)]
