Mongler98
- Joined
- Mar 23, 2011
- Location
- COLORADO (SE of Denver)
- TDI
- 98 Jetta TDI AHU 1.9L (944 TDI swap in progress) I moved so now i got nothing but an AHU in a garage on a pallet.
Think of it this way. if you had a material, like a carpet, when you vacuum it, its easy to go in one direction vs the other as the grain is going one direction. this is how your snow tires work. your running them the wrong direction. The high point of the angled tread is supposed to go into the wheel against the road, causing the rubber to deform and cause excessive grip. If its backwards the tread deforms with the grain and not against the road surface and would act like a slick tire. For now just drop your PSI down to 25psi and hope for the best until you get it done. Go to pick up some bags of sand or something heavy and put it in your trunk if you can to add some traction.
