ewenmaclean
Hello,
I have a 99 2.5tdi T4 (Eurovan) with an ACV engine. It's been running fine - last time I set up the timing I had it pretty much spot on (65) on VCDS.
Recently the idle speed has been a bit higher than I expected (825 rather than 775) so I check with VCDS. No fault codes, apparently all the temp reading seem feasible to me. I checked the timing when warm and it is way too advanced (93). It's running fine, but I can't think what would cause the timing to have jumped in this way.
The ACV has two timing belts - one for the cam and water pump and crank, and one from the cam to the pump. This has a tensioner which can be used to advance or retard the timing. If this slips it would naturally retard the timing.
I am wondering if perhaps the pump itself has some internal problem. I am loathed to set the timing again for the pump, only for the dynamic advance to not function.
I am wondering what might have caused the timing to suddenly become advanced. Any insights very gratefully received.
thanks
thanks
