Hi All,
My son has a 2004 Jetta TDI which he had some start and run issues with last winter however as soon as the air temps warmed into the 40's / 50's it was fine - it has started and ran fine all summer. This morning the air temp was in the high 30's for the first time and it started but died a couple miles down the road - same as last winter. Occasionally, it simply won't start at all if it is in the 20's to single digits. But primarily it will start and die later either on the road or in the driveway.
It doesn't have to be freezing for this to occur, in fact this morning was 38. I would estimate that it will infact start most of the time and die while he lets it warm up ... minutes later.
As the daytime temps warm, it has never failed to start right up when we try it later. If he keeps it inside out of the cold air, it has never failed to start and run.
Moisture is not a factor today and as for precipitation in general, it doesn't seem to matter.
Wondering where to start?
