short to plus intermitet sometimes work sometimes no power, 120 ohms warm if it is working when vcds has no read from the sensor i read around 240 ohms.
Unpuging and pluging connector sometimes helps for a minute.
What is confusing me sometimes sensor reads 120 ohm 13V is on connector but when i connect G80 no signal, it is probably G80 fault in coil but i don't want to buy one and then it turns out there is sometning with ECU, intersting is that only 2 weaks before it started i installed cruise control, probably it is just coincidence but who knows
