Got the codes again. Here is the scan.
I've got the extended emissions warranty, but I don't want to take it to the dealer if it's something I can fix myself.
Sunday,04,March,2018,12:28:23:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: 1VWBN7A34CC058091 License Plate:
Address 01: Engine Labels: None
Control Module Part Number: 03L 997 009 J HW: 03L 907 309 S
Component and/or Version: R4 2.0l TDI H21 9981
Software Coding: 001D0012842400000000
Work Shop Code: WSC 91507 999 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004004 (VW41)
VCID: 3B75D167B2907BC6811-806E
No ASAM data for: "EV_ECM20TDI01103L997009J" (VW41)
3 Faults Found:
8842 - ROD - Unknown Error Code
- 00 [232]
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 120815 km
Date: 2068.14.27
Time: 11:41:38
8844 - ROD - Unknown Error Code
- 00 [096]
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 120815 km
Date: 2068.14.27
Time: 11:41:38
8845 - ROD - Unknown Error Code
- 00 [096]
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 120815 km
Date: 2068.14.27
Time: 11:41:38
Readiness: 1 1 0 0 0
Sunday,04,March,2018,12:30:14:62939
Address 01: Engine
Advanced Identification/FAZIT
Serial number:
Identification: BPG-810
Revision: 71H21---
Date: 28.12.11
Manufacturer number: 1242
Test stand number: 0469
Flash Status
Programming Attempts(application): 2/2/2
Successful Attempts(application): 2/2/2
Flash Date: 17.12.06
Misc.
Hardware number: 03L 907 309 S
Workshop System Name: J623
ASAM Dataset Revision: 004004
Car Info
Chassis Number: 1VWBN7A34CC058091
Engine code: CKRA
VCDS Info:
Labels: None
Readiness: No script available
ROD: ERROR - EV_ECM20TDI01103L997009J 004004 (VW41)
