PD Engine stalls when Hot; won't restart . .
rdkern
Humboldt Co CA
Throwing parts or not is rather unimportant at this point. Let em replace it - I hope it is the problem so you can be driving a good car again. Let's return to the other potentials if this isn't it.
How different is the current ecu from the prior ones? This does make sense - I used to have a computer (in the dinosaur days) that didn't have an internal fan, and would go wonky after being used for 2 hours or so. Perhaps the chips in these cars are starting to get too big to rely on ambient cooling? At least in the summer.
whitedog
Bend, Oregon
So, would a hot engine correlate/cause the in-tank fuel pump to intermitently fail?
This is just a wild guess, so get out the saline IV for this.
Hot engine would mean that the fuel is hot. Hot fuel causes a contact to break in the fuel pump, causing no pumpy.
So, why wouldn't the fuel cooler keep the fuel cool enough? Is there a problem with that, causing excessivly hot fuel to return to tank? If the fuel cooler is plugged with mud, it wouldn't cool very well.
Now that's all blue-sky, rambling and I don't know how close I could be, but it's something to think about.
Sadly, it does not address the GP light issue.
rdkern
Humboldt Co CA
So - get this to the dealer, and let's find out if changing the ecu fixes it. If not, we have IV- (generally filled with beer/wine) fueled members to guess the next problem.
Ry-dog
Central Mass
2014 Jetta Sportswagen
Got the car back from the dealership. They replaced the ECU and re-programmed my keys all covered under warranty.
Looks like this fixed the problem. I have certainly replicated the conditions that would cause my car to stall out and not start prior to the ECU replacement many times and it runs great.
I guess more time will tell for sure, but I don't think its the in-tank fuel pump since it is running great now with the new ECU. The service manager indicated that VW tech headquarters said they have seen this overheating ECU on a number of the PDs, thus that is why they did my replacement.
I'll post back if the problem comes back - if not, problem was fixed with new ECU.
rdkern
Humboldt Co CA
That is good news. Keep us informed of any changes.
