triclopsrobot
Hi all, I recently bought a very tidy 2004 New Beetle 1.9 tdi. After noticing a bit of knocking and grinding I took it back to the garage and they fitted a replacement gearbox (the bearings had gone) and new clutch. The scary noises have now completely gone and it's driving really smooth but the only problem is I occasionally have difficulty getting into 1st gear. It's resisting going in rather than crunching or popping out of gear, usually at stop signals when I am in more of a rush to find the gear.
It's not every time, just occasionally, I try and fail to put it into gear, go back to neutral, let out the clutch then try again and it goes in.
I'm guessing the clutch might need adjusting? Is that a big job and if I don't get it fixed right away will it get worse? I'm supposed to be driving off on holiday this weekend and don't want to risk it if it's potentially going to break down.
Cheers for any advice.
