[Mk4 Golf - 200k]
The passenger side coil spring snapped about a 4 inch piece from the bottom.
The I'm looking at replacing the coil springs with something just as soft as stock, or even softer. Not firmer.
The current ride is a bit firm i would say - maybe it's just firmer because the current setup has ran its lifespan. To my knowledge everything suspension wise is original. Had the car for 100k.
Any suggestions for a place to get the springs from? Should I replace the struts/shocks too? The dealer says that the struts are made for the lifetime of the vehicle and shouldn't be replaced ...
If not a place to buy them from, what kind of struts/springs to go for. The OEM strut/spring combo from the dealer would be around 1400 (350 per wheel).
I was looking at the Bilstein TCs, but those claim they are a bit firmer than stock. Not sure i like the sound of that.
(Any threads with directions on shock/spring replacement for the rear?)
