evolveVW
Here's the short of it for now, Ill tell the back story later..
Set static timing, everything is good and set with the necessary tools. IP timing pin set at approx. 1 o'clock and lined up visually with the pump as shown in other threads.
Here is the problem, with static timing set, IP timing is still too retarded. Even with full glow due to CTS disconnect, it will be hard to start and not run all the time. Lots of fuel smoke, and when running will shut down after revving. Will not start at all with CTS connected. ASV is clean and functional. Fuel shutoff solenoid replaced not too long ago. I'm tempted to advance the IP gear one tooth and see what happens. Thoughts?
