How to post pics:
1. Go here
http://tdipics.mmcorp.net/ and open an account. This server is for TDIClub use only!
2. Once you are in your account on the pic server, click on "upload" and then "browse." Locate the JPEG file on your hard drive and upload it to the pic server.
3. To add the pic to a post in the Forum, get into your account on the pic server (I like to open a second browser to do this while my original one is open to the Forums) and right-click on the file you want to post. Select "copy shortcut".
4. In your Forum post, put the cursor where you want the pic to appear and then look at the "Instant UBB Code" list just below the text window. Click on "Image." A window will pop up. Right click in the window and select "paste." The link to your picture will appear. Hit "enter." To do this manually, you simply type the URL for your picture in-between the UBB image tags: {img} and {/img}, except you use square brackets instead of the fancy ones. The first one tells the UBB software "A picture link follows...." and the second one says "That was a picture link just now...got it?"
Example (Make sure you use square brackets instead of fancy ones):
{img}http://www.mickeysuglypics.com/myhairybutt.jpg{/img}
-mickey
